Imported file line work not displaying.
3 ANTWORTEN 3
Nachricht 1 von 4
254 Aufrufe, 3 Antworten
Hi I'm new to Revit and am having issues with importing a .dwg site file.
It looks as if it imported, but the line work is not appearing.
I tried opening it from a different computer and it opens correctly.
I've attached a print screen .doc. for your reference.
Thank You,
Nicholas
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
I only see 2 points. You need a minimum of 3.  Can you explain your workflow step by step?
Nachricht 3 von 4
When you import the DWG for the topography, make sure the box Visible for Current View Only is NOT ticked.
Nachricht 4 von 4
Corsten.Au
Hi
If you can see only few points of topography then probably you
just need to fix the view range..
make sure you are cutting above the topography and lower range is set to unlimited or
atleast where it will capture the site..
hope you ll find it..
Cheers !
Corsten
Building Designer
