Announcements
VISIBILITY
VISIBILITY
The columns are visible in 3D view and not visible in the elevation. ALthough under the visibility graphics the columns and strutural columns are ticked. With so many setting and endless amount of options autodesk softwares have its quite impossible to find tutorials which are limited , even classes , completely useful .
josemukalel
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
Thanks . It wasalraedy ticked so the case wasn't your solution. I just reloaded the same column into th eproject again and it worked. But manythanks anyway. My software seems to have a bug
RDAOU
Hello @Anonymous
There are no specific tutorials to such things because they are not related to a specific cause. ie: It may occure due to various reasons; example
  1. Wrong Discipline
  2. Visibility Graphics settings
  3. Element/Column is outside the Extents of the elevation/sections/scopebox (somewhat the equiv. of view range for sections and elevations)
  4. VG was overriden for that specific Category of elements / Category was previously set to hidden on that view / View template applied
  5. Family visibility settings (example: All objects/elements are set to show in 3D by default unless view settings where overridden)
  6. Wrong Constraints
  7. Element is obsecured by a masking region
  8. ...etc
Thats why in most cases the solution would be a wild guess when the question is not quite detailed or is not accompanied with a file or screencast...However; once one has spent some more time using Revit (several 100 hours) one gets the hang of the Revit Workflow and one does such double checks without even thinking
