Visibility's dependent on Two Parameters | Matrix
Message 1 of 9
So I have two parameters at play here:
 1. PalletsPerBay
Determines no. pallets on x-axis
2. No.Beams
Determines no. pallets on y-axis
I need the families two be dependent on both parameters. Please see image attached.
I used a couple of if(and()) statements but this seems tedious. Is there an easier way to do this? Maybe I could create visibility parameters dependent on two conditions?
(I forgot to add 01, 02, & 03 parameters to the list, but the idea remains the same)
Accepted solutions (3)
Replies (8)
Message 2 of 9
Why don't you nest the pallet family in the beam family so that when you place a beam the pallet comes with it?
Message 3 of 9
Are you Arraying in both the x and y directions simultaneously?  If so, I've accomplished something similar by nesting a parametric array into another parametric array, which in turn, is nested into a host.
Message 4 of 9
Thanks for the advice guys.
@barthbradley, I don't believe an array will work as there could be 1 pallet per bay, and you need at least 2 for an array, correct?
@ToanDN@barthbradley
So I nested the pallets with the beams in a family: Beams&Pallets.
Please refer to image attached:
- Blue indicates hidden beams
- Red indicates hidden pallets
The nested families that are hidden are dependent only on the No.Beams visibility of host Beams&Pallets family, and therefore hide easily.
However:
Pallets 22, 23, 32, 33 are dependent on No.Beams in host family (Rack) and PalletsPerBeam in nested family (Beams&Pallets). Now they won't hide unless No.Beams PalletsPerBeam yes/no is false.
How can I resolve this?
Thanks in advance,
Connor
Message 5 of 9
So as a solution:
I created instance yes/no parameters for Pallet 2 & Pallet 3 in Beams&Pallets associated to their relevant pallets.
Then I associated these instance parameters to equivalent yes/no parameters in the host, which I made dependent on if statement formulas.
Let me know if you guys know of a better way to go about it please.
Message 6 of 9
You can use array. Insert two modules in the same place, assign one with a vis param "array", one with a vis param "single". Enter a formula for "single" = not (array). Array parametrically the "array" module as usual. When you need 1 module, use a chexkbox to turn off "array" then "single" will show.
Message 7 of 9
Thanks man
Message 8 of 9
Actually, I have array families that have a single element state. This is easily accomplished through On/Off parameters. One  On/Off parameter controls the visibility of the element Array and another On/Off parameter controls the visibility of a single element.  So, if than number of elements is less the 2; the Array default to 2 elements and becomes invisible, and the single element becomes visible.
Message 9 of 9
Ja, Toan did mention that. Thanks man.
