visibility overriedes confusion
3 REPLIES 3
pipapongo0909
275 Views, 3 Replies
hi forum,
i am struggling for weeks now to understand the. visibility overrides in combination with view range, and i have come to the conclusion the Autodesk guys are willingly keeping the confusion. i cant explain why thete is no better material for learning out there. i had some days of in person trainng by an autodesk certified trainer and he could ( nor would) give me any clear answers on any topic.
if things have been programmed it shoulf be the easy part to explain it. sorry but what is this worth as an explanation. it basically says it could be this or this but also something else
""There are a number of ways to override the display of an element.
It may not always be clear which method of override takes priority over another method, that is, which method "wins" in determining the display of the element. The following list may not cover every scenario, but it includes some common overrides.""
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
sincerlely, a frustrated Revit user
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
3 REPLIES 3
in reply to: pipapongo0909
Give us an example of a scenario that confuses you.
It is very well explained in that article, in the link you posted. What else could be said about this?
pipapongo0909
in reply to: ToanDN
hi ToanDN,
it is not one example per se. i find it prezty hard to find good documentation about Revit. most of the docs tell you what is obvious and kind of explain out of context.
mybe i am looking in the wrong places but i get the feeling that all i have been figuring out untill now could have been done in 20% of that time with the proper documentation. the link i posted does not tell the hole truth since materials are not meantionned but they play a huge role in the decision how you want things to appear. i am building an inhouse documentation about all this things to tell my users
Jeff Wurth
LinkedIn
