visibility order according to phasing within one view
hi there!
I would like to have the demolished parts BEHIND the new construction.. ???
in the pic red is new, yellow demolished..
Thanks!
Ahmed_M_Heteba
there is no draw order command in revit.
you have to work around it using view range and view depth
you can also use transparency to achieve the view you need
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Ahmed_M_Heteba
you might also use line work option if you want to hide some lines
hi Ahmed,
I looked into your suggestions, while I am still relatively new in revit, I am not sure..
the thing is that I have 2 overlapping walls, one is new construction, the other is to be demolished.
The demolished one appears complete and the new is partially hidden behind, I would like to have it the other way around..
RobDraw
If this is for a sheet view, you might consider showing the demolition in a separate view for clarity.
Rob
