Visibility of Intersection Line between Wall and Floor in 3D Model
ABapatS7HWK
ABapatS7HWK
Hi, Intersection line between a basic wall and a generic floor in my 3D view is not visible. Despite checking my visibility settings, Could anyone advise on how to make this intersection line visible?  Thanks,
Thanks for the help, It worked, with Join tool. Now how can we make it for Topography and wall?
ralphdenhaan
- You can use the Cut/Join tool to cut/join the floor from the walls.
- Or adjust the profile of the floor around the walls.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Use Join Geometry (and Switch Join Order if needed).
ABapatS7HWK
Worked!
ABapatS7HWK
Great, thanks. It worked. Now how can I make the intersection line appear for Topography and wall intersection? Join tool is not selecting topography.
ralphdenhaan
Since you are working in Revit 2023 or earlier you can work with a Building Pad. With (Revit 2024 you can use the Cut tool or make a Mass Void).
Make a type with a Thickness of about 50mm and draw it around your foundation at the bottom Level for example:
