Visibility graphics items are grayed out (disabled)
sonyablade2010
Message 1 of 18
sonyablade2010
Dear All,
I'm getting that famous "None of the created elements are visible in Floor Plan: ..... View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings." message during tagging the revision cloud.
In orer to eliminate that if I go to View Visibility/graphics button I see that everything under it model, annotations etcc categories is disabled, I can see that revision cloud checkbox is marked but revision cloud tag is not marked, how am I supposed to change it, so that it will place the tag on revision clouds.
Replies (17)
Message 2 of 18
vicoars
Do you have view template applied to that view?
Message 3 of 18
sonyablade2010
yes that was the source of malfunctioning thank you
Message 4 of 18
khalidhmohamed
To resolve for grayed out visibility graphic;
Go to the properties box > Identity data > view template: NONE, Title on sheet : <empty>
Message 5 of 18
I think that they sorted this problem out some years ago.
Message 6 of 18
You saved my life! 10 years later
Message 7 of 18
Wild idea- if a view template disable V/G under 'Graphics', why not just grey it out at the Properties panel?? Why do users come back year after year after year with the same questions?? What kind of company runs this way? Especially when the fee is THOUSANDS of dollars per user per year.
Message 8 of 18
Lance.Coffey
Autodesk Support
Autodesk Support
Some additional information for those encountering this behavior in the future.
If you are looking to make a temporary change to the view (that doesn’t need to be saved/retained), you can use the Temporary View Properties command (from the View Control Bar).
Lance Coffey
Technical Support Specialist
Message 9 of 18
RobDraw
Here's another wild idea. How about people ask questions about why something works the way it does before flying off the handle?
The reason it is not greyed out is because the view template does not have to control everything and when it doesn't those items can be accessed from V/G overrides button.
Because people being people, they make the same mistakes as those before them. I've supported tons of people and I get the same questions again and again. It's called human nature.
The problem isn't the company. They can't be in the trenches holding hands with every newbie who hasn't gotten proper training.
Rob
Message 10 of 18
Thanks a lot, you have solved my problem that was going to drive me crazy!!!
Message 11 of 18
mhiserZFHXS
Everyone knows Revit isn't perfect, but boy do I get a kick out of people who come in here and think other programs are better... There is a reason its the industry norm y'all. Does Autodesk take that for granted? Probably. Do some programs have individual features that work better than Revit? Yes. Is Revit still better than those other programs overall? Definitely.
Message 12 of 18
A01373336
Observer
Observer
Thank you!
Message 13 of 18
endes4455
I have the same parameter settings but the visibility menu is still greyed out in 3D. In my fourth day of trial, I didn't expect to experience such elementary user interface problems.
Message 14 of 18
RSomppi
There is definitely a learning curve for Revit. Don't expect to be able to just jump in and be productive without any training or learning. There are a number of resources for learning the basics.
Message 15 of 18
soudageraamer
Observer
Observer
We don't deserve you!!!!
I'm crying internally right now!!!!!
Message 16 of 18
RASHIK_PANCHAL
Community Visitor
Community Visitor
Not solved this  problem
Message 17 of 18
RSomppi
Sure it is. What part are you havning trouble with?
Message 18 of 18
jbEDP
Community Visitor
Community Visitor
That did not work for me.
