Visibility/Graphics for Point Clouds - elevation
AMPI_PL
Message 1 of 20
AMPI_PL
Is there any way to display point cloud witch graphical override set to Elevation but witch adjusted value min and max? Like you can in recap, autocad or infraworks?
Replies (19)
Message 2 of 20
Why don't you do it with View Range extents.  Just set the Cut Plane and Top, Bottom and Depth to remove/include those Points needed in that View.
Message 3 of 20
AMPI_PL
Changing the range does not affect the coloring of the point clouds because the extreme values ​​are taken from the point cloud anyway. I don't want to remove the points, just to make it visible on the print which elements are above which. From what I see, it's sad that you can get it in other programs with a few clicks, but there is no such option here.
Message 4 of 20
I simply misunderstood your end goal.  I thought this was about constructing a model from points.
This is what you are after; yes?
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-8D691E44-85EC-4F71-B043-1946802449AC
Message 5 of 20
AMPI_PL
Yes. And I need a simple functionality to specify max and min values of colour gradient. For given cases, I use about 40% of the elevation range of point cloud - when it color due to whole range the differences are too small.
Message 6 of 20
I'm still not understanding what you're trying to accomplish or what the end goal is.  What do you mean when you say "I use about 40% of the elevation range" ?  Use it how?
Message 7 of 20
AMPI_PL
I have points in the cloud from 0 to 100 meters let's assume. In the drawing I have a part of an object where the elements range from e.g. 0-40 meters. The program colors the point cloud globally in the range of 0-100 meters, so the difference in colors in the range of 0-40 is unfortunately barely noticeable.
This is what the same piece of scanning looks like in AutoCAD and Revit, with the difference that in AutoCAD I can easily set the min/max height range for extreme colors. So I ask again: is there any way or a paid add-on that allows you to do this, or is Revit limited even in such a trivial matter (I don't even mention the possibility of setting the size of points in the scanning because I have already come to terms with it)?
Message 8 of 20
As I said previously in this thread, you can limit the range via the View's View Range settings.  I have no idea why you would want a 40 meter or 100 meter range in Plan View.  What would be the purpose?  Isn't the sole purpose of bringing the Point Cloud into Revit to serve as a reference for modeling?
Message 9 of 20
AMPI_PL
Thank you for your help, but I don't think you understand the function I'm asking about and what it provides. Limiting the displayed points using the function is not even close to what I want to achieve. I don't also do models based on PC either.
Message 10 of 20
Agreed. I don't understand the function you are asking about and because of that, I don't understand what "it" provides. Additionally confounding to me, is that you say you "don't...do models based on PC".  Love to know what it is that you do do with PCs in Revit.  You haven't articulated that once.
Message 11 of 20
AMPI_PL
This is recap - with 2-3 clicks i can set min and max height point of colour gradient. How to do this in revit cause now i see that i can do this in almost every program of AEC collection. Almost because revit cant do it.
Message 12 of 20
Okay, so why do you ask?  Why do you want that?  For fun? because it looks pretty?  Revit doesn't make coffee either, but there are appliances that do.
Bing Videos
Message 13 of 20
AMPI_PL
Let me explain - you have pipes, cables or whatever that are located on different levels, for example on the first floor of a 10-story building. In AutoCAD, Infraworks or in the recap, I can easily set the view mode to recognize what is over or below what in top view. That you dont understand case dont mean that someone dont need this elemental features. Please leave this thread
Message 14 of 20
You first.
Message 15 of 20
josephbrown.design
Community Visitor
Community Visitor
@AMPI_PL  Did you ever find an answer/solution to this as I am struggling to do the same? No point in an elevation view for a pointcloud if you cant set the range of the elevations!
Message 16 of 20
DanielBrook
Sad to see such hostility in this thread. It was a reasonable question. I can see many reasons to want to control the elevation range. For instance, I am assessing the deviation of a concrete slab from a point cloud survey. As mentioned, recap easily does this, but it would be useful to have this ability inside of Revit rather than taking screen shots from recap. I ended up just cutting a new point cloud for the specific level range I was interest in and loading this in as an additional link.
Message 17 of 20
Simon_Weel
Post is as idea in the Ideas-forum?
Message 18 of 20
AMPI_PL
Unfortunately, I did not find a solution. All that remains is to cut out the different levels into separate cloudfiles and color them in different colors. Maybe in REVIT2030 they will unify the way the programs in the package work 🙂
Message 19 of 20
sagnewYUXLR
what a thread lol
Message 20 of 20
noahE7UMA
@AMPI_PL You were making perfect sense and I respect you keeping your cool amoungst such pointlessly hostile responses.
I am having the same issues regarding the weaving of pipes visible in an RCP. The functionality you describe is exactly what I am looking for, allowing quick over/under evaluation within a bracketed elevation min/max range in plan or RCP.
