Visibility and Graphic Display : Problem
Message 1 of 27
Hi
We have a problem with the "Visibility and Graphis Display" box. More specifically, the "Annotation Categories" box.
In one model, it takes like 10-15 minutes before we can have access to the modification box when we are clicking on it.
In another one, We just never have access to it because Revit is always trying to open it and it never does. So we always have to close Revit and re-open it to continue working...
It began in the first model and I think that happened in the second model when I transfered some of the project standards from the first model (like object styles, light weights or line styles).
You can see in the attachment file that it stucks to "Model Categories" when we click on "Annotation Categories".
What can be the causes of all this?!
We are using Revit 2015.
Thank you.
Replies (26)
Message 21 of 27
I've been able to find when this happened (with backup files). I then compared 2 back up files (1 that worked and 1 that doesn't). I checked every single family and groups of family. They seem fine.
Thanks for your help though.
Message 22 of 27
rodrigo.bezerra
@loboarch, are you aware of some issue like @Anonymous's?
Rodrigo Bezerra
Message 23 of 27
loboarch
Honestly don't know. If I was to guess some kind of "bad" annotation family was loaded with a ton of subcategories or something. I would send along to Product Support as well. The could have dev compare a "good" file to a "bad" file and perhaps find the reason.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 24 of 27
jmcouffin
hey,
I have pretty much the same problem here, a file just got slow, trying to VV it...
I compared both files (fast and slow) and did not find anything relevant.
did you find something in the end or did you just redid the work?
Message 25 of 27
Je peux répondre en français? (Are you speaking french?) J'ai une solution et ça serait plus simple à expliquer.
Car en voyant ton nom d'utilisateur, je crois que tu es à Montréal. Je suis chez GLCRM, à Québec.
Message 26 of 27
patrick.emin
Bonjour, pour votre information il existe maintenant un forum Revit en français: http://forums.autodesk.com/t5/revit-et-bim-francais/bd-p/198
FYI, there is now a french Revit forum.
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 27 of 27
jmcouffin
thanks;
we both know about it.
and 90% of revit users can speak English...
so to find a solution to a Revit mess, we deal in the main trade language 😛
as for a solution.
I got a subcategory linetype in the component detail category that copied itself more than 100 000+ times
the same linetype...
it took me hours to figure out why VV graphics visibility settings tooks minutes to open.
I tried deleting them all at once... no chance.
then I took a bunch of them (around 5000 at a time) and deleted them... it took me a few minutes and fixed the problem.
we did not find out if it was a specific family that caused the problem yet.
another solution is to run a macro.
you can find a base here and here too and here
or to make a dynamo routine.
