Visailabillty of hatch
glkirk
glkirk
Does anyone know why I get the see thru of thi hatch pattern in the program and after converting to pdf?
Thanks!
Jason_S
By chance did "Overwrite Graphics in View" and Transparency get turned on in your view for that element or wall?
Does it show transparent in the elevation?
syman2000
Check and see if the material has 100% transparency. Set it to 0 so it will not see thru.
glkirk
Gosh you were right and I thought I looked into that!
It was not in over ride graphics in view
Thank you both!
Does anyone know where I can get a pat file a bit closer to the "Stacked stone" that is so popular now?
Thanks again.
hmunsell
i was going to say your Thin Line (TL) was turned on in your view, that will effect how you see the linework in your view. but if @syman2000  worked, that's great too. don't forget to mark it as the solution :-)....
Howard Munsell
