Views in Linked model
naomi2BHGT
Message 1 of 11
naomi2BHGT
In my linked model have views set up that use scope boxes. I went to visibility Graphics and I changed the link display to "by linked view", however, the floor view I selected uses a scope box and instead the linked model shows the entire floor. Is there a way to get it to just show only what is in the scope box?
Replies (10)
Message 2 of 11
Did you actually apply the scope box to the view?
TIP: Turn on Annotation Crop in Plan Views.
Message 3 of 11
naomi2BHGT
In the original model yes. When it is linked into another model those scope boxes are no longer accessible. I did not copy any scope boxes into the new project i'm linking to either.
Message 4 of 11
Message 5 of 11
Do you want to apply the same scope box to the entire view or just the linked model in the view?
Message 6 of 11
naomi2BHGT
I want to just be able to isolate a view in the linked model. Or would I have to just use visibility graphics for it.
Message 7 of 11
That is understood.  Are you okay with your view also being cropped the same way?
Message 8 of 11
naomi2BHGT
Do you mean the entire floor view of the new project? If so, then no just for the linked model. If actually using a scope box changes more than just the linked model, then I may just have to use visibility graphics for that view.
Message 9 of 11
So you want something like this?
Message 10 of 11
naomi2BHGT
Yes
Message 11 of 11
@naomi2BHGT wrote:
Yes
Then you need to overlay two views with different scope boxes, or different view crop regions on sheet.
