viewport title location on sheets
kantoor
kantoor
Hello all,
Is there a way to adjust the location of the viewport title when inserting an Assembly view on a sheet?
When inserting I get the view like below and I manually have to relocate the title to a desired position.
Lehtinen5BZBJ
I think Viewport titles behave the same way regardless of the viewtype. In Revit you have to position the titles to your desired position manually, and even just aligning them is a relatively new feature (2022). But you can always use Dynamo to do the work for you. For example: https://designtechunraveled.com/2021/08/06/revit-cant-do-that-part-2/
RSomppi
Being able to align them with tracking has been around a lot longer than that.
handjonathan
Hi @kantoor
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Lehtinen5BZBJ helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
