Viewport and Sheet Dimensions problem
hello everyone
I have one problem in using annotations in details and plans via sheets.
for example we have two viewports(plan and callout) with different scales(1/100-1/20) and same dimension type
(text size = 2.5 mm).after using this viewports in sheet (A1) all dimension text size are the same(based on cad drawing standards).but in this situation in callout viewport it is very difficult to draw and annotate elements and we should use another dimension style whit bigger text size(for example 5mm) to make every annotations seems good.
in this case after using different annotation styles, placing this viewport in another sheet makes problem. that dimension text size are not the same.
please see the attached video.
@Anonymous wrote:
...dimension text size are not the same.
They look the same to me.
martijn_pater
The annotation size is related to the plot size on sheet, not to view size... is that what you meant? If you want to use a different size you'll need to create, or duplicate/edit, the dimension type accordingly...
ennujozlagam
looks like there is no issues with different scale in the title block sheets, unless your issues is different? thanks
