View Title Cross Reference
PhilvK
Advisor Advisor
PhilvK
The sheet number highlighted in yellow below is the sheet my view is being placed on. The sheet number highlighted in blue is the sheet where it is being called out. On some of my drawings, the sheet where the view is being called out (blue) is not appearing. Any clues on what to check would be appreciated.
PhilvK
I found the problem. I can't find the callout on the plan that is referencing the elevation view, and therefore the callout doesn't appear on a numbered sheet. The problem now is that I have an elevation view with apparently no callout!
PhilvK
Found the answer. I right clicked the elevation view in the Project Browser and found where it was being referenced from by clicking 'Find Referring Views'.
Mike.FORM
Also you may want to check the elevation view property "hide at scales courser than" as it may be set to something like 1:5 and thus not showing on you larger plans.
mari.shimode
Hi @PhilvK, it looks like you solved the issue yourself. I have marked your reply as an accepted solution so others who have the same question can find it easily. Please visit the Autodesk Community again when you have any other questions.
Mari Shimode
