view template mismatch floor plan
Message 1 of 9
I have created several floor plans and then assigned view templates with appropriate names  in the type properties. (Plumbing floor plan - plumbing view template,  Hydronics floor plan - hydronics view template).
However, when I go exactly to a floor plan, view templates do not match the floor plan (as shown below in red).
How can I fix it, so the view template automatically changes according to the floor plan?
Replies (8)
Message 2 of 9
"View Template applied to NEW views", not existing.
Message 3 of 9
Where can I find that?
Message 4 of 9
I'm saying: create a brand new Floor Plan and it will use that template. It doesn't work retroactively.
Message 5 of 9
peteregan
Egan BIM Resources has an app for that. This is a free app.
It is called Project Startup and is available from the Egan BIM Resources web site or the Apps Exchange.
From the Help file:
Automatically Swap View Template When View Type Is Changed
If a View Type has a “View Templates applied to new views” setting, and “New views are dependent on template” is checked, the app will automatically apply the correct view template whenever a view’s View Type is changed.
Message 6 of 9
italonge
Same problem here... Would be very nice to change the Flor Type and automatically change de View Template...
Message 7 of 9
bgarcia-rawinterational
Message 8 of 9
RSomppi
Did you happen to discover it in the post directly above the one you responded to, Message 5 of 7?
"Egan BIM Resources has an app for that. This is a free app."
Message 9 of 9
I found it browsing the market Autodesk App Store a few days ago. There is plenty of great tools but installing too many tends to hinder my Revit workflow rather then optimize it. Apologies on the redundancy, I didn't realize it was already shared above.
