View's "Save to New File" command saves the whole project instead of this view only
nikolay.gerasimov3SGFN
Message 1 of 9
I haven't used this function for a while, but I do remember, that it should save only elements visible on the view. Looks like not anymore (since 2021). Is it a bug or a feature?
Replies (8)
Message 2 of 9
jay_colcombe
This is still available from File > Save As > Library > View but is limited for specific View Types
If you need to share a model and strip it out you manually need to delete views and sheets and purge etc,
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 9
It saves the model if you are trying to save a model view to a new file.  What you remember was with drafting views.
Message 4 of 9
****. Annotaion crop must be enabled too. Thx everyone.
Message 5 of 9
costelos
try this:
  • select the desired items and make a Group
  • then from Save As >Library>Group and save it as a New Revit File
  • Open it or use it as a Linked File
Message 6 of 9
constantin.stroescu
try this:
sorry for first post from costelos
Constantin Stroescu
Message 7 of 9
This is also a way, but it will cutt off these elements from the model. Not exactly what we need.
Message 8 of 9
Cut Off? ...No way..
Constantin Stroescu
Message 9 of 9
jay_colcombe
Hi, can you clarify the process so other who search for this can use the solution when searching - thanks
Jay Colcombe
