VIEW RANGE IN BASEMENT CEILINGT PLAN
rclement
rclement
book tells me to create a basement ceiling plan. np
says will look a little funny so i have to adjust the view range
click modify and then set view range to 6'6" wont let me do it.
Ceiling Plan View Range is backass-backwards.
chadwickt
I use the same textbook.
The view range by default is at 7'-6", which puts it into the first floor. That is what you are currently seeing in your ceiling plan. Make sure nothing is selected (the book tells you to click Modify, I usually just hit Escape twice). Then you should be able to select Edit... next to View Range, then adjust the Cut plane to 6'-6". I was able to do it to your file so I am betting you will be able to as well!2020-10-26_13-55-14.jpg
JML_Mela
@barthbradley
This is the best sheet regarding View range that i have seen!
Congrats!
