Ribbon lag
Ribbon lag
jelmer.eekman
Ribbon lag
jelmer.eekman
We encounter this horrible Ribbon lag (see attachment).
I've heard multiple users within our company complaining about this.
We use Revit 2020 all updates
I work on big projects (1gb + filesize)
Is this a known issue? Any suggestion is welcome.
L.Maas
Never seen this behaviour before. Is this just happening when you have a large project open?
-Have you checked the task manager (CTRL-ALT-DEL, Task manager)?
-Fulfil the system specs?
-Enough memory (rule of thumb: 20x project file)?
-Other software that might interfere (e/g virusscanners)
-Some colleagues similar problem and some not. Differences between computer with and without issues?
Louis
Please mention Revit version, especially when uploading Revit files.
jelmer.eekman
-Have you checked the task manager (CTRL-ALT-DEL, Task manager)? Yes, checked it and therefor installed 32gb memery but it still occurs
-Fulfil the system specs? Intel(R) Core(TM) i7-4710MQ CPU @ 2.50GHz 2.50 GHz, NVidia Quadro K3100M, should do the trick imo
-Enough memory (rule of thumb: 20x project file)? 32gb
-Other software that might interfere (e/g virusscanners) Perhaps but how can I figure this one out...
-Some colleagues similar problem and some not. Differences between computer with and without issues? I'll have to investigate this
