!View Range - Depth below
mairh_tsek
mairh_tsek
Hello all,
I had setup the view range and I 'Tranfered Project Standards' from another project.
I noticed that the view range had changed too, and the Bottom plan is grey out (why?)
I want also to set the view depth below in order to see the floor ans I get the error ' View depth is set below the top clip plan'. (image attached)
Do you have any solution how can I see the floor (level 00_brut , height offset 0.0 in my floor plans ? )
Thank you in advance !
mairh_tsek
Sorry I found the answer...It was because of the view direction, It should be set 'Down' .. ( Image attanched )
Sound like you have overwritten some setting.  What element is grayed out?
Regarding the View Range issue : is that a Ceiling Plan View?
