I have 2 types of floor in my project:
Structural and non-Structural
I want to create a 3D view that displays Beams, Columns, and STRUCTURAL floor.
Is it possible to di this using Visibility Graphic?
I don't want to select non-structural floors and hide them, because I and adding new floors and should hide any new floor manually. So, I am looking to do this using VG.
Gelöst! Gehe zur Lösung
Gelöst von saeednajafi22. Gehe zur Lösung
If you include something like 'Structural" in the naming of your structural floors, you can create a filter for floors that will only show floors with 'Structural' included in the name. You can then use the filter in other views if required.
I created a filter using the "Structure" property of "Floor" and worked.
Hey,
I am looking to only show the structural floor part in plan so that I can do spot elevation to show the concrete slab level and not the finished floor level.
Is this possible?
For this you can also select "Bottom Elevation" just under the Ribbon when you are placing the Spot Elevation.
This way you can leave the Architectural Finished Floor displayed, but still report the level of the Structural floor.
