View range comparison - Unlimited depth but different visibility
12 REPLIES 12
Message 1 of 13
cbt990
661 Views, 12 Replies
Here is a snip of a foundation plan - the green segment is a slightly deepened.
I have created a callout view. I can't get the deepened footing to display even though the view range is set to unlimited:
Revit is amazing
12 REPLIES 12
Message 2 of 13
in reply to: cbt990
Create the callout as Floor Plan, not Detail.
Message 3 of 13
cbt990
in reply to: ToanDN
Revit is amazing
Message 4 of 13
in reply to: cbt990
Do you want to share the model for an immediate answer or keep playing the guessing game?
https://www.revitforum.org/node/459
Message 5 of 13
in reply to: cbt990
Did you create that Linework in the View with the Linework Tool. Betcha did.
Message 6 of 13
cbt990
in reply to: barthbradley
rEAL BIM
Revit is amazing
Message 7 of 13
cbt990
in reply to: ToanDN
it works without issue in this dummy model.
Revit is amazing
Message 8 of 13
in reply to: cbt990
 I don't see any issues with it. What am looking for?
Message 9 of 13
in reply to: cbt990
Reveal Hidden Element?
Message 10 of 13
cbt990
Deepened footing visible when intersected by cut plane:
Also see:
Depth of view extents somehow is reduced when I raise the cut plane:
Revit is amazing
Message 11 of 13
in reply to: cbt990
Use a Plan Region then.
Sounds like you are describing Low Wall behavior (e.g. <4'-0").  Read more here:
About the View Range | Revit 2019 | Autodesk Knowledge Network
Message 12 of 13
cbt990
Is there a way to hide the boundary of the plan region?
Revit is amazing
Message 13 of 13
cbt990
in reply to: cbt990
It was another element causing the line. Thanks for the help.
Revit is amazing
