VG Overrides - Filters
arkitek2ss
arkitek2ss
In V/G Overrides under Filters, curious on how the filters are listed?
definitely not alphabetical.
Never thought about it.  Just added the ones I needed. Why do you ask?
arkitek2ss
Just wondering.  thought maybe in alphabetical so I was creating the filters based on major-minor i.e.  Walls - Sweeps.  unless someone else has a better naming convention of filters.
They are listed based on the order of creation, maybe.
I think you are absolutely right, @ToanDN.  That's how you re-order parameters in Families. You temporarily recreate the Family Parameters as in the order your want as Project Parameters.  You know what I'm talking about; right?
The order of the filters determines which filter is applied last. Therefore you can change the order manually.
Suppose you have two filters.
Filter 1: Color all walls red.
Filter 2: Color all objects on level 2 blue.
What color are the walls on level 2 now?
If filter 1 is higher than filter 2: Red.
If filter 2 is higher than filter 1: Blue.
