VG: Linked models
VG: Linked models
XXalessio.amodioXX
VG: Linked models
XXalessio.amodioXX
Hi all,
I am trying to change visualization using Visual Graphic into the linked model, but I had to prepare a filter instead.
Any idea why is it happening?
TripleM-Dev.net
Changing the color by the (sub) category only works if the geometry is actually in that (subb)category.
The family can be Category X but there can be a nested family of category Y (open the pipe family and inspect)
The filter works because if overrides the whole element no matter what category is in it (it's a ALL change action)
- Michel
XXalessio.amodioXX
From some other models it works properly e.g. Electrical model.
So I would like to know if there is some kind of detailed filtering hierarchy.
No Subcategory involved.
TripleM-Dev.net
True, it could be a Phase or discipline setting for example that changes the element, then setting the category would also do nothing.
There should be a doc/post somewhere listing the order completely.
For Projection/Cut lines/patterns.
1. User manually overide element = Will override anything graphics setting (can't be applied to linked elements)
2. ViewFilters  (order of the viewfilters also matters)
3. Phase setting (I think viewfilters can override Phase settings)
? Discipline settings like hidden lines in Structural etc
4. Category/subcategory setting.
Found one: Revit Visibility Hierarchy
- Michel
