Vertical opening within roof-based family
g_thong
Message 1 of 10
g_thong
I'm trying to create a vertical opening that is hosted in a rooflight, so that if I place the window in a sloped roof, the opening will still be vertical in the project. Is this possible? I'm working in Revit 2023
Thanks!
Replies (9)
Message 2 of 10
Are you talking about skylight shaft walls? If so, use Project Walls.
Message 3 of 10
g_thong
Sorry, what do you mean by project walls?
Message 4 of 10
Please confirm. Are you talking about the skylight shaft?
Message 5 of 10
g_thong
Yes I am. Our roof buildup is quite thick so it is very obvious that the opening is not vertical, but is instead perpendicular to the rooflight.
Message 6 of 10
Are you using the Attach Top/Base Tool to attach vertical walls to the roof?
...wait a minute. are you talking about the opening?  Remove the opening cut from the Window Family and use a Shaft to cut the opening in the Project.  Or use an In-Place Void Extrusion.
Message 7 of 10
syman2000
It is possible, you have to built a family with angle.
Message 8 of 10
g_thong
Thank you, I was hoping I'd be able to have the opening hosted in the family so it would update with the size of the rooflight, but this is also a solution
Message 9 of 10
g_thong
Thank you for this! Do you know if there is any way to have the roof of the slope reported as a reporting parameter, or is this not possible?
Message 10 of 10
syman2000
Currently it isn't possible.
