- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi!
I am currently in the process of drawing a detail of a curved exterior wall. I'm using a default section as a detail view. The problem I'm having is that even though the section is exactly perpendicular to the curve of the wall, nothing will snap to vertical lines - similar to how an elevation misbehaves when it's not exactly perpendicular to a face. This makes annotation and aligning extra difficult. It looks correct and the measure tool gives the right numbers.
Is there a way get this working properly without drawing an straight dummy wall + floors etc. off to the side of the project and make the section through that? It semi-works as it is, but I'd really prefer to be able to align and annotate. Ideas? I'm pretty new to Revit so I fell I may have missed something.
This is the offending section/detail:
