I am trying to create a door family where the panels self populate using an array. I have managed to get it to work horizontally but now I want them to space out equally vertically across the frame and the 1st and the last panel to align with the edge of the frame. I can get the 1st part to work, but not the second part.
My frame formula is based on a supplier's frame depth and is:
"Frame Depth=Number of Panels*62mm"
My Vertical array of the Panels is then as follows:
((Frame Depth- (Door Panel Thickness * Number of Panels)) / Number of Panels) + Door Panel Thickness
Which leaves my door looking almost ok, but not quite right as the last panel does not align to the frame, see snippet
The top left panel is 22mm off the frame edge.
I have a parameter assigned to the dimension between the start of the second panel and the frame edge, and I think that's why there's a 22mm gap. But...can I change the formula around to make this work or do I need to draw the dimension to the middle of the panel?
Any ideas?
Thanks!
