Vertical Array formula to align door panels
laura.johanssonPN37Y
I am trying to create a door family where the panels self populate using an array. I have managed to get it to work horizontally but now I want them to space out equally vertically across the frame and the 1st and the last panel to align with the edge of the frame. I can get the 1st part to work, but not the second part.
My frame formula is based on a supplier's frame depth and is:
"Frame Depth=Number of Panels*62mm"
My Vertical array of the Panels is then as follows:
((Frame Depth- (Door Panel Thickness * Number of Panels)) / Number of Panels) + Door Panel Thickness
Which leaves my door looking almost ok, but not quite right as the last panel does not align to the frame, see snippet
The top left panel is 22mm off the frame edge.
I have a parameter assigned to the dimension between the start of the second panel and the frame edge, and I think that's why there's a 22mm gap. But...can I change the formula around to make this work or do I need to draw the dimension to the middle of the panel?
Any ideas?
Thanks!
Why do you add Door Thickness to the formula for Frame Depth? Should Frame Depth = Number of panels * Door Thickness?
It Would be,  but Door panel size is fixed,  based on a supplier's door frame. Otherwise yes,  that would have been the frame size.  But according to the supplier the door frame for 2 panels is 124mm.
mhiserZFHXS
Why not change the array to "Move To: Last" and align the exterior face of the panel to the reference plane determining frame depth? Then you don't need an equation for that spacing. It'll just automatically space the panels.
124 mm frame = 2*62 mm.  Your formula is adding another 62 mm to that so that why it is wrong.
Hi @mhiserZFHXS
I tried that as well but then I get an error with the constraints and the panels break and start overlapping each other. See snippet:
This is when I went from 3 to 5 panels and I made the array (to last) and aligned to frame edge. I've tried with reference planes, without reference planes, dimensioning and locking and it still has a constraing error and I have to remove constraints in order to add/remove panels and then they break like that. :s
I also changed the formula for the door frame depth to Number of panels*Door Panel Thickness as the formula did not work. Somehow the distance became bigger from the frame edge.
So still no luck. Any suggestions, anyone?
So that was just  a Revit bug, once I restarted Revit the family behaved as normal and spaced out the panels as required when using the array to last and formula Depth=Number of Panels * Panel thickness.
