Vector printing problem with phasing elements
mertH2237
mertH2237
I have a project where there is phasing. The demolished elements are represented as yellow dashed lines and the new elements are represented with red. The problem is that the elements are overlapping and when I try to plot as vector plotter only chooses one of the elements and completely ignores the other one. It plots properly on raster processing but the issue is it increases the file size a lot and makes it hard to navigate through the pdf file. Is there a workaround for this.
Thank You
I see coincident linework.  Just wondering if "Region edges mask coincident lines" would have an effect.  It doesn't make sense that it would, but I would probably try anyways.
Unfortunately, non black lines staying above black lines is just one of Revit things that annoy most people.
- Try the native PDF Export see any improvement
- If you have Bluebeam printer, turn on Line Merge and play with Blend mode
