Variation in lineweights of family surface patterns
- Mute
- Permalink
- Report
Thanks to forums like this I have found so many answers to Revit issues I have had. I really appreciate all of the help people are willing to provide using this program. This is the first time I have had to post anything, as I have not been able to find a resolution to an issue I am having with some family surface lineweights.
I am working on a model that has a lot of structural timber families. These timbers have a material assigned to them which has a wood grain model pattern assigned. I have made it grey for visualization purposes.
Most of the timbers appear in drawing views and 3D views with a "thin" grain pattern, but a minority have a "thick" grain pattern. Oddly these are the exact same families....I open the family files up and they are the same name and have all of the same attributes. I did not originally create this model so maybe there is an issue with how it was built.
My understanding from searching for an answer to this is that there is no way to control the lineweight thickness of a family, at least directly. I have noticed that when I copy the thicker grain pattern timbers the copied version is thin grained. I can go thru and copy these all in place and then delete the ones I don't want but it is a bit of pain as there are a lot and they will need to be retagged. Also, I feel like I could do this and then it could reappear as thick again or something.
I already had an issue with this model which I was able to do a workaround on which was that I had grids turned off in a view template but they were still showing in the views that the view template was applied to. Every time I closed and opened the model they would be there. I tried everything including auditing the model and eventually just turned them off manually!
Below are images of the variation in lineweights that I am seeing, any help would be greatly appreciated.
