using spt. file for revit families
1 REPLY 1
432 Views, 1 Reply
hallo..
I get an object in spt. file. I want use the object to my revit. Is it possible that the spt. file convert into rfa. file then, I can load it into the revit. How is it work, maybe I should convert it to other extention file before it's used in revit?
1 REPLY 1
thamizhz
can convert ur spt to ifc or any other support format. then go to insert u can access as a block.
