- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The following is a sample containing simple walls and floors. The blue cuboid is a Mass I wish to use to "cut up" the Walls and Floors that intersect the edges of the Mass, i.e. determine the volume of the elements contained within the Mass.
As can be seen in the picture, it works when dividing along the vertical planes. However, for it to work perfectly, one more division would have to be created parallel to the two horizontal planes of the Mass.
I have attached the Dynamo graph I used to accomplish this result.
I suspect that my final goal is not doable within Dynamo due to lack of workplane controls. Would this be possible using the API?
