Using an If yes/ no Statment to control a dimension parameter
Message 1 of 8
I would like to control a Dimension parameter by using a if Statement.
The goal is; when you check the Full Beam Pocket to yes it will automatically set the Beam Pocket Depth to equal the Panel Thickness, if no then it should remain 3 1/2"
The current formula is   ** if(Full Beam Pocket, 1, 0) = Panel Thickness **
Replies (7)
Message 2 of 8
aren't you there?
if(Full Beam Pocket, Panel Thickness, 3 1/2").
No?
Message 3 of 8
That is the formula I entered and it is not working.   I'm not sure what needs to change.  I'm hoping someone can see what I'm missing.
Message 4 of 8
Make Panel Thickness an Instance Parameter
...or all the associated parameters Type Parameters
Message 5 of 8
aoffak
I tried to something similar but Revit 2022 was nice enough to give me a hint (<boolean>, <result if true, result if false). Therefore try the following to see if it works:
if(Full Beam Pocket, Stud Spacing, 3.5")
Message 6 of 8
mhiserZFHXS
If using a Yes/No parameter in a formula, you just need to type the parameter name and then the result if true and the result if false. Don't need an equal sign anywhere in the equation.
if(Yes/No Parameter, Result if True, Result if False).
Message 7 of 8
callumwebb
For clarification as I made this mistake, the above is correct however you only need the results no "If True" statement next to the results as below.
Message 8 of 8
Mike.FORM
@mhiserZFHXS was not sayin you need to write "If True".
It is stating the first value is what will be used if the Yes/No Parameter is checked, ie "Result if True" and the second value is what will be used if the Yes/No Parameter is unchecked, ie "Result if False".
