Open the cad file in Autocad. Orient the View Cube to a 3d axonometric/isometric view.
Is everything "flat"--or do you see any lines projecting into 3d space?
Purging and exploding polylines should not change the orientation. But just to be sure, I suppose the polylines could have been 3d polylines ( with Z values )
Since it came into Revit rotated in 3d, it sounds like its UCS may have changed. That should NOT have happened.
If so, use the "flatten" command in Autocad, and select ALL when prompted. If FLATTEN says "unknown command", it may need to be loaded as a LISP routine. If that's the case, check the AutoCad Forums.
Anyway--As I mentioned earlier, creating .dwg files from PDFs in Adobe Illustrator can cause some very odd results in the resulating .dwg file.
Make sure you thoroughly clean it up, purge , etc in Acad before linking it into Revit.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
