Use same view template for floor/ceiling/section/elevation/3D views?
HVAC-Novice
Advisor Advisor
HVAC-Novice
For one reason or another I always had separate view templates for each discipline for ceiling, floor section etc. So my mechanical views actually have at least 4-5 templates (one for floor, one for ceiling and so on). Same for architectural, lighting etc.
This has the disadvantage that if I want to make a change (make something show in half-tone, or in fine, or to make something not show at all, or apply filter to make specific systems be in a color etc.), I have to apply the same change to all 4-5 templates of one discipline.
But now I have the idea to just use the same discipline template to all the view types in a discipline. I tried that out in a small project and it seems to work fine so far. But I haven't tested it thoroughly yet. The only downside seems to be, that if I want to change the view template, I have t change the view type filter to "all" (since my general view template is based on a floor template, it doesn't show up by default in ceiling views and I have to manually show all view templates.
I work in multiple disciplines (A, M, P, Lighting, Electrical). So consolidating view templates would make things easier. Now this sounds like a really good idea, but I'm sure there is a reason to do it my original way (separate templates for floor etc.).
My questions (assuming in one discipline I want to show everything in the same way in all view types):
- is there an unintended consequence or drawback to just use the same view template per discipline?
- Does anybody else use a single template per discipline, or does everyone use a separate template for ceiling, floor, 3D etc.? and why do you prefer the one method over the other?
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
There some properties only applicable to certain types of views such as View Range, Underlay, Orientation, System Color Schemes for Plan/RCP; or Depth Cueing for Section/Elevation.  If those need not to be controlled by your view templates then sure you can share one template for different view types.
HVAC-Novice
Thanks. It looks like floor plan templates has the most adjustment options. So I base my template on a floor template. the available options in a template change once I apply it to a different type of view.
I think for this small project I just keep trying it out until I run into a wall.
