Use Formulas, Parameters, Labels to Change the Display Text of a Dimension
brianorser
Message 1 of 10
brianorser
Hello
I need a dimension to display a different number than the unit length of the measured object. In other words, if the dimension is measuring an object that is 1' long, I need the dimension to instead display (1' * .9) or "0.9". I am ready to use any means, including Grasshopper or Python or C+, and am able to invest significant time in creating this solution.
I have been trying using labels and global parameters, but am falling short.
Thank you,
Brian
Replies (9)
Message 2 of 10
Why can't you scale the model to the correct size instead of faking the dimensions?
Message 3 of 10
brianorser
I need the drawings to display both Imperial dimensions (for the Building Department) and Shaku, a traditional Japanese decimal system which the carpenters will use to build the building.
Message 4 of 10
Yes I got that. Link the rhino model in Revit, choose feet for import units, then select it, edit type and change Scale factor from 1 to 0.9...
Message 5 of 10
brianorser
Hello ToanDN
Your suggestion is a method for scaling the model, not a method for dimensioning and creating schedules in Feet-Inches and Shaku.
Message 6 of 10
Exactly. Now you have two instances of the link. One scaled 1:1 to dimension in shaku. One scaled  0.9:1to do dimension in feet.
Message 7 of 10
anze.kumar
You could try manully replacing dimension value with text - which is a lot of manual work.
Then create two different types of Dimension Styles: one in Imperial and one in traditional Japanese.
Once everything is dimensioned, duplicate the View with Deatiling -> select all instances of dimensions -> replace them with other type.
Message 8 of 10
carl-marcus.ekstromDDJLJ
Hi, create a detail item line based family for the dimensions. Then you can create a scaled value of the length
Message 9 of 10
brianorser
This is an interesting workaround--thanks. Not ideal, but something to consider.
Message 10 of 10
brianorser
Hi
This would only work for us if the replacement value is calculated automatically. I'll need to pursue that in Python or Dynamo.
