URGENT Please help me REVIT wont allow me to place wall footing onto the wall.
5 REPLIES 5
1101 Views, 5 Replies
It says None of the created elements are visible in Structural Plan: Ground Floor View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
Can anyone provide a simple solution with detailed images in it?
5 REPLIES 5
This message indicates that Revit did place the elements, but that you can't see them in the view you are in.  This is likely because the elements don't intersect the View Range. So, change View Range settings, if you need them visible in this view.
Keep this list for future reference:
http://www.therevitblog.com/2013/04/cant-see-it-in-view-heres-33-reasons.html
in reply to: barthbradley
How can I change the view range?
Corsten.Au
Hi..
Try Changing the view to " Fine " or Medium...
Cheers !
Corsten
Building Designer
@Anonymous
@barthbradley is correct.  More specifically, you are placing Footing under Walls and the View Depth is not far enough to show the Footing.  Follow the screenshot below to fix it.
