RDAOU
try to disable Antivirus and Firewall if that doesn't work contact your Network/IT administrator
MostafaElashmawy
I think the best way to install Autodesk software is using direct link to download the files (SFX) then install.
go to below link to find the 3 direct links to download 3 parts of revit then double click the first part and Revit will install.
most of installation problems don't occur with this method.
https://forums.autodesk.com/t5/installation-licensing/autodesk-2019-products-direct-links-until-avai...
Mostafa Elashmawy
RDAOU
Ideally you shouldn't follow those Trial links considering the fact that Revit 2019 is already on Autodesk Virtual Agent hence those links may be outdated and/or not the final release and/or bugged/not maintained
The ideal way to download Autodesk Software is either the Account Manager or from https://ava.autodesk.com/
It is still recommended to switch off both Antivirus and Firewall till installation is complete
