unlock Revit file in ACC
lucas_porto5DJ9Y
Message 1 of 8
lucas_porto5DJ9Y
Hi everyone.
I have one revit cloud model in ACC that is locked with one old employee.
I'm sure that this file is not opened with he and I can lost the changes made by hem without problem.
There is any way to unlock the file?
I would like to keep the file's historic version.
Thanks.
Replies (7)
Message 2 of 8
SteveKStafford
Download the file and create a new central file from it, upload to ACC. Archive the copy and delete the prior one from ACC.
Steve Stafford
Message 3 of 8
lucas_porto5DJ9Y
The file is not shared file. It is configured to run just for one person.
The problem about this process is that I will lose all the past version of the file and is important to keep the history.
Message 4 of 8
SteveKStafford
What do you mean when you write "locked"?
Steve Stafford
Message 5 of 8
lucas_porto5DJ9Y
This:
Revit block the access because for it this user is with the file open but this user doesn't exist more.
Message 6 of 8
SteveKStafford
Are you able to review the history of the file and restore from an earlier version? What about Force Relinquish?
Steve Stafford
Message 7 of 8
lucas_porto5DJ9Y
Unfortunately, it is a Cloud Model but not a Workshared Cloud Model.
I can't go back 1 version because I need those changes saved, the problem is the user access the file after the last version that is saved in ACC and I didn't find a way to turn around this situation.
Message 8 of 8
SteveKStafford
If the file is not using worksharing then it doesn't have a "history" you can "keep" so if you download the file you'll have whatever that file had when it was posted.
Steve Stafford
