Unexpected representation behavior when loading windows with nested families
Pediaditakis
Pediaditakis
I have been recently working on some new window families for our firm. The frame is built as an extrusion in the window family, while the panels, interior and exterior sills are modelled as nested. The exterior sill is shared as I wanted it to cut walls in a certain way. The issue is that when I first load the window in a project, it seems that the sill has the wrong size, until I place the family when the size is correct. Has anyone else experienced that or know what could possibly the cause be?
See the images bellow:
before placing
after placing
Thanks for your help!
vitorbortoncello
When a shared nested family is first loaded into a project, Revit may initially display the wrong size due to a temporary mismatch between the family’s instance parameters and the project environment. Once the family is placed, Revit recalculates and adjusts the geometry to fit the project conditions, which could explain why the size corrects itself.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
handjonathan
Hi @Pediaditakis
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
