UNDO OPTION AFTER SYNCHRONIZATION WITH CENTRAL
Dear All,
                    I had done some changes by copying central model file to my local desktop and then clicked on synchronize with central.Now i need to undo that synchronized file so that changes are not included in central file.
Mahesh
CoreyDaun
Those changes cannot be undone. You will have to either manually undo the changes or revert to a previous version of the Central File, which will affect other users' work during that time period. Refer to Revit Help or search this forum for instructions/tips on restoring backup files.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
david.burow
Found this thread Googling for a how-to on unrolling changes made to a central file.  There actually is a way to "undo" changes sync'ed with Central, but it involves restoring a backup and overwriting the Central.  This method is outlined here:
https://knowledge.autodesk.com/guidref/RVT/NaN/learn-explore/GUID-CCD8B86A-C1CF-4D6F-A36E-BDCD7B8191...
