Underlay settings
Underlay settings
tcoco
Underlay settings
tcoco
I am working on a multi story apartment building. The kitchens and bathrooms are links. When I work on a floor plan and underlay another floorplan the bathrooms and kitchens are not visible. Is there a way to make these visible?
Thank you.
Alfredo_Medina
In the VG of the current view, under the Revit Links tab, select the links that are not showing up, and use these two settings: underlay, and by linked view.
tcoco
This does get the link to show in the underlay, now the links of every level show up not only the one I set the underlay to and when I set the underlay to none they still show?
Alfredo_Medina
If you have multiple instances of the link, then you need to apply the settings to the proper instance of the link, in each view. As in this example:
