Inserting sheets with legends from a different file
I am trying to insert views from a different file onto another one however these contain live views and legends. The live views are easy to remove and redo bu there are multiple legends per sheet that will need to be redone. Is there a workaround that will allow me to transfer the whole sheet to a new file?
Thanks!
Antonio
nathan.chapman
There is no copy legends from project to project button.  What you can do though is create a legend in the project you want to transfer to.  Now go to the project with the existing legend and copy all the elements to the clipboard.  Go back to new legend and paste.  This isn't the best workflow but the only one at this time.  Just be aware that if the legends scales don't match you could have issue.  As far as sheets they can be transferred as long as no legends are on it using the insert view from file.
Nate
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
Alfredo_Medina
Copy-paste from one legend to another legend in a different project is the only way. Unfortunately, legends are not on the list of views that can be inserted from one project to another.
