Underlay not showing above
Message 1 of 12
I need to show the fitouts from level 2 on the plan view of level 1 but I can't make that work. I have been messing with the underlay combination looking up and down and changing view range for more than 2 hours and nothing works!
Help!
Accepted solutions (3)
Replies (11)
Message 2 of 12
Share a section and your plan/underlay settings.
Message 3 of 12
I can see windows above but no walls, partitions or furniture shows see photos
Annotation 2020-02-03 222713.pngAnnotation 2020-02-03 223412.pngAnnotation 2020-02-03 224039s.png
Message 4 of 12
RDAOU
@Anonymous
Upload model or test the following, and tell what do you see
Test 1
  1. If walls are attached to slab Level 3; Detach walls
  2. Set unconnected height >= than the Primary Range Top of the view range
<post screenshot>
Test 2:
  • Add a level datum at Level 3 "Bottom of Slab" ...Call it say L3-BOS just for reference
  • set underlay "Range: Top" to the L3-BOS
<post screenshot>
Message 5 of 12
What is your Level 1 view range setting? Make sure the Top does not go above Level 2.
Message 6 of 12
The view range is not above level 2 see in the photos below for both level 1 and 2.
If I detach the walls they become 2500mm unconnected and they show in level 1 as underlay but not the furniture. This solved part of the problem but not sure how or why
Message 7 of 12
Can you share the model?
Did a test myself: you can change the floors category to 100% transparency, or select the 2nd level floor in teh section view and hide/make it transparent in the level 1 plan view.
Message 8 of 12
RDAOU
@Anonymous
The 2nd floor is more of a Mezzanine (2.2m high) … setting the underlay Top to Level 3 and looking down => floor slab on 3rd floor is blocking the view of the walls and furniture (that is why when you detach you see the walls  when they extend above the floor element @ Level 3 but not the furniture because they are hidden below floor.
Option 1:
  • If it is a temp thing, go to visibility graphics and Hide the floor elements temporarily...do whatever you need to do then unhide it
Option 2:
  • leave your walls as they are attached  to the floor slab @ level 3
  • leave the underlay settings same to what you posted earlier
  • use Wireframe
Option 3:
  • Add a level at the bottom of the slab (BOS) as mentioned above
  • Attach walls back to floor @ level 3 or set top constraint to BOS datum
  • set the underlay top to the datum @ BOS (this will cancel the floor slab @ level 3 from the equation
Message 9 of 12
Phasing?
Message 10 of 12
The hide floor and wireframe worked. Everything is shown now. I didn't add the level because I dont want to add more views. Thanks for the help.
Now I hope the location lines issue will be solved
Message 11 of 12
All is 1 phase. I'm not using phasing
Message 12 of 12
RDAOU
@Anonymous
Here is a link to "View Range of Underlays" kinda explains why the floor slab you had on level 3 (falling entirely between the underlay top and bottom range) was hiding your elements on the second floor
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/View-range-of-underlay.h...
For the additional datum (it could be useful for structural plan - you can delete the RCP and Architectural Plans)...also useful if you want to keep the underlay to place on sheets
