Uncooperative Calculated Values in Furniture Schedule
Sahay_R
Mentor Mentor
Message 1 of 17
Sahay_R
What's wrong with this schedule?
This is what I need to see - with Itemize Each Instance unchecked
The highlighted fields are formula driven -
Both Total Existing and Total Proposed are Shared Number Parameters.
I understand that this is a problem, that prevents the formula from working -
Is there any way around this? I don't want to ask my team to calculate and manually enter values!
Thank you in advance....
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Accepted solutions (4)
Replies (16)
Message 2 of 17
Hiya Rina.
Can you post it?
Message 3 of 17
You need to enter 0 for all blank cells of Existing Seats, Existing BF, New Seats, New BF.
Message 4 of 17
Sahay_R
Here's the deal, @ToanDN  - can't add the 0s. The Proposed Seats and Proposed BFs have a Shared Parameter with a value of 1 so that they schedule by that parameter and give actual counts. The Existing is an invisible 'dummy' family that has a Shared Parameter for the sole purpose of entering the numbers since we do not want to model the existing seating.
Per @barthbradley 's wish - here is a link to the file -
https://autode.sk/38lRQKC
Rina Sahay
Message 5 of 17
Who says you can't?
Message 6 of 17
Sahay_R
OK - you added the parameters to the project - that was the step that I was missing....THANK YOU!
Rina Sahay
Message 7 of 17
I just edit the parameters directly from the schedule and assign them to the Rooms/Doors categories.  By the way, you don't need to use shared parameters for any of those fields, everything can be added as non-shared parameters directly in the project's schedule.
Message 8 of 17
Sahay_R
I just assigned them to Furniture. How did you edit the parameters right out of the schedule?
(Hang on - I see them as Shared Parameters assigned to Furniture and Rooms in your project....)
And also - those parameters come from the Families, and if they aren't Shared I can't schedule for that parameter....
Rina Sahay
Message 9 of 17
Fields tab, select the parameter, Edit button, tick Add to all... box, then tick the category box(es).
Message 10 of 17
Sahay_R
Aahh. Another way to add a Shared parameter to the project..... Thank you!
Rina Sahay
Message 11 of 17
Sahay_R
And now what's wrong with this?
This is the desired result....
Rina Sahay
Message 12 of 17
You cannot divide by zero.
Message 13 of 17
Sahay_R
After coming so far.....
What would you suggest? Creating hidden fields for Total Existing and Total Proposed, and using them in a calculated field for the Percentage Decrease?> My head hurts now......
Rina Sahay
Message 14 of 17
I suggest you use the furniture schedule to get the count of the new pieces, then re-enter them in a room schedule to get the calculated % and whatnots.
Message 15 of 17
Sahay_R
Would that mean stitching the two schedules together on the sheet? A FrankenSchedule, so as to speak?
Rina Sahay
Message 16 of 17
Since you have to re-enter the values to the room schedule anyways so just use one schedule.  Keep the furniture schedule for validation should the design changes.
Message 17 of 17
Sahay_R
Right - that's what I did - created two hidden fields, manually entered the numbers in there to feed the calculated parameter that gave the percentage decrease values. All is well now.
Rina Sahay
