Uncheck every parameter
yes_and_no
yes_and_no
I have a simple family of boring equipments as sub families with little twist in detail to differentiate themselves apart, using parameters.
Problem is when I create a new parameter, this parameter will appear across these equipments, so I have to go unclick every subfamilies. Is there a way to unclick all of them at once, or something I missed ? Forgive me if this been answered before.
Sounds like you are creating a Yes/No Parameter and its default is checked for all the Family Types, but you want it unchecked. If so, type "1=2" into the Formula Field of the Parameter and hit Apply.  Now remove the Formula and check the box for that one Family Type.
yes_and_no
Thank you so much.
You save me hundred of clicking, considering I have about 25 sub families with 25 little associated details.
That s 1=2 trick, 🙂
You're welcome, but the idea here is to mark the post that actually provides the solution as the Accepted Solution - not the post that thanks the author for providing the Accepted Solution. Get it?
yes_and_no
Thx.
I wonder what happens if I enter "1=1" ?
@yes_and_no wrote:
Thx.
You can answer the question by determine if the equation is TRUE or FALSE.
1=1 means TRUE so the box will be checked. (it can be 0=0, 2=2, 1>0, etc...)
1= 2 means FALSE so the box will be unchecked (same as 1=0, 1<0, etc..)
enawabi
Thanks worked for me also.
