Unbind Binded Link
Unbind Binded Link
Unbind Binded Link
Can I do it? Unbind a already binded link? When I first started the project, I have accidentaly selected "Bind Link". It made the architeture file and the MEP file become a single file, instead of a MEP file linked to an architeture file. Now as a result I can't update architeture file (which should be just a link).
Here's a picture of this "Bind Link" button I've selected:
martijn_pater
Delete - reinsert in same position? Are you using coordinates?
Yes. Select the group, use Link button on the ribbon and follow the prompt to convert it back to a link.
I vote re-link.  Delete what you "binded" and start afresh.
BTW: I don't know the reason you originally binded the Link, but you might look at the Copy/Monitor functions next time you are tempted.
I've ungrouped it before. I cannot select the architetural part whitout selecting the MEP one, but I think there is somehow because Revit recognizes the MEP parts in the filters 
Managed to do it guys, thank you all.
It might help someone else so: I just had to select the entire house in the 3d view with a selection window, then I selected the Filter in the modify options up in the ribbon. Then, I selected all the items except for the MEP items (those that are conduits, plumbs, lightning devices, etc.) and I hit ok. With that done, the last step is to delete all the selection you've made, then you are good to go and make another link
rizwanalam5704
Community Visitor
Community Visitor
Hi un bind link
