Unable to unhide element
Message 1 of 11
I hid my viewport title and am not able to unhide it. It won’t give me the option
Replies (10)
Message 2 of 11
have you tried to see it with the 'reveal hidden elements' ..... see attached
then you might be able to unhide it?!
Message 3 of 11
ennujozlagam
@Anonymous hello, in addition, just click your viewport > properties > edit type change to yes. please see screen shot. thanks
Message 4 of 11
chrisplyler
This appears to be a bug. If you hide a view title by-element, you are unable to un-hide it.
You may need to delete the view from the sheet, and then place it on the sheet again.
Message 5 of 11
How do you hide a View Title by element?  When I tried the Option is grayed out.  I can only hide the entire Viewport which will hide the Title also, but it can be revealed normally.
Message 6 of 11
chrisplyler
AHA! Maybe that is the missing fact in this case!
Maybe he hid the entire viewport, and then is trying to unhide just the title.
Message 7 of 11
If that the case then turn on the infamous light bulb will reveal the viewport and the title.  Select viewport, NOT the title, and Unhide it.
Message 8 of 11
This was the most helpful answer in regards to trying to unhide my sheet title. I did not realize that my viewport was hidden as well. When I tried right clicking the view title to unhide, it would not give me the option to unhide. when I clicked my viewport outline and right clicked to unhide, it actually worked and my view title reappeared. I did not realize the viewport and sheet title were interconnected. The rest of the answers are what I already tried but this was the most efficient answer for a sheet title issue not being able to be unhidden.
Message 9 of 11
Luke-RA
This was helpful and solved my issue. I turned the viewport to visible, then hit 'shown hidden' then right clicked and unhide element was possible.
Message 10 of 11
avelasquezYH84W
Observer
Observer
This saved my bacon!!! Thank you!!!
Message 11 of 11
cfranklinUXDKQ
Community Visitor
Community Visitor
There is a way to "Unhide" detail views. Just hit the lightbulb at the bottom of the screen, select the border of the detail view and select unhide. Do not select the title, this will not work.
