unable to see items and including sample projects in revit
I'm unable to see the loaded items on my screen however they are being created on my screen.Pls provide a solution for it
ennujozlagam
hello can you go to options and see if you can see same like my screenshot attached. thanks
if no, you can refer to this LINK. thanks
Basam.Yousif
Do you mean that you are unable to see the elements you are creating on screen??
That can be caused by a list of reasons:
1. The current workset is closed or hidden in view
2. category\sub-cat is hidden in the view
3. view range
4. filter
5. Linked DWG masking it
6. Phase filter\settings
7. Mass object masking it
8. Design option
9. View property "Display model" is set to "Do not display"
RobDraw
That list should be a lot longer.
Rob
martijn_pater
You must be refering to the list of 41 reasons why things don't show in a view...
@Anonymous Your question is somewhat unclear, perhaps elaborate with a snapshot of what you are looking at. For linked elements you could check visibility graphics (in template) for revit links or imported categories if these loaded elements (?) are turned off there. But not sure if that's what you are looking for.
