Unable to Rescale objects/ rescale is greyed out
samurtha
samurtha
Community Visitor
Community Visitor
I Imported a geometry from Rhino into Revit and for an assignment and the geometry is not letting me rescale it in revit. the object is unpinned
Not sure how you import the Rhino object in but try select it, edit type, and see if you can access the Scale factor.  If you can't, then scale it in Rhino.
samurtha
Community Visitor
Community Visitor
I Figured it out thank you though,  I didn't realize my geometry had walls on it already, apparently you cant scale the walls but you can the geometry itself
