Unable to modify an hidden line
Shay.Gaghe
Shay.Gaghe
Hi all
I have a wall , and toposurface elevated with building pad objects. I want to show those hidden lines so I go to Graphic> show hidden lines , I select the wall and than to toposurface. The thing is that I would like to make the border invisible using the line style but it cannot be selected.
Any idea?
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
Ahmed_Muharram
try to use linework from modify tab
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Linework doesn't work on hidden lines. Try to join the wall and the building pad see if that line goes away.
Shay.Gaghe
are you sure building pads can be joined? i tried but it doesn't seem possible (even if they share the same material)
No I am not sure, no Revit at the moment. Maybe model the wall as another thicker pad and join the two pads.  If that still doesn't work,  create a line style with 254 254 254 color, draw it over the hidden lines.
